Max Chip Speed for 875P Chipset Motherboard
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.abit,comp.sys.intel (More info?)
Does anyone know how "upgradable" the 875P Chipset (for example, ABit
IC7-G Motherboard) is ?
In other words, I'll probably be buying a P4 HT 3.0C. Are there plans
down the road for Intel to continue making faster chips that will fit
in this motherboard ? If so, is the motherboard maxed-out at 3.4 GHz
(currently the fastest CPU available for this board), or is it
expected to be able to handle, for example, a 4 GHz CPU ?
FWIW, I'm not planning on overclocking, Thanks for the assistance.
the current Northwood and first generation Prescott CPU's will fit this
board. Intel does not really have plans for the Northwood to go much higher
in speed than where it currently is, from my reading. The Prescott will
change form factor and continue the climb in speed as I understand it from
published articles. when Prescott changes form factor, it will no longer be
compatible with socket 478.
Thomas Geery
Network+ certified
ftp://geerynet.d2g.com
ftp://68.98.180.8 Abit Mirror <----- Cable modem IP
This IP is dynamic so it *could* change!...
over 130,000 FTP users served!
<tony010409020622@spamthis@hotmail.com> wrote in message
news:ngtia0pvsao6lhbgj5p7jupk4ilh0rjg10@4ax.com...
