Hi guys, I'm planning on making an HTPC build on one of Intel's new Kaby Lake non-K CPUs. I was wondering what would be the best possible specs for the memory which would be compatible with my system:
* CPU - Intel i7 7700
* Mobo - MSI Z270i Gaming Carbon Pro AC
* CPU Cooler - Noctua L9i
* SSD - Samsung 850 EVO 250GB M.2-2280
* HDD - (2x) WD Black 2.5" 7200RPM
* GPU - MSI GTX1070 Founder's Edition
* PSU - Corsair SF600 SFX
Thinking of using a (2x8GB) 16GB memory configuration and I'm currently undecided with the following selection with regards to their compatibility and performance:
* Corsair Vengeance LPX 2400MHz CL14
* Corsair Vengeance LPX 2666MHz CL16
Both of the configurations are pretty much at the same price point so budget won't be a problem.
Was also wondering if there would be any issues in choosing memory modules with higher speeds, like a 3200Mhz one for example, since they specified in Intel's product page that the i7 7700 can only support 2133MHz and 2400Mhz, but at the same time, the MSI Z270i Carbon motherboard supports speeds up to 3800MHz. As such, what would be the maximum memory speed compatible with an i7 7700 without having to overclock the CPU (since I obviously can't with a non-K skew).
Would very much appreciate any advice and suggestions. Thanks in advance
