[SOLVED] Max Core Frequency
https://ark.intel.com/products/126686/Intel-Core-i7-8700-Processor-12M-Cache-up-to-4-60-GHz-
I believe 4.3 is the max speed for all cores... Sounds right
is there a way i could limit it at 3.7 or 3.6 ghz in intel exetreme utility?.
Why couldn't you just invest in a decent cooling solution? There are options out there that are not that expensive that should keep the temps under control at factory settings. I'm also going to assume that you've already confirmed the cooling solution you have is properly installed and you have proper airflow in the case. I also forgot to add you could try undervolting the chip to see if that gets temps under control.
