N Nexus2422 Honorable Nov 22, 2013 25 0 10,530 Jun 19, 2015 #1 I am considering buying the case but i cant find max psu other then "ps2 atx" size ....
Phillip Corcoran Titan Moderator Sep 7, 2013 26,107 912 120,140 Jun 19, 2015 #2 By "max" I assume you're referring to max PSU dimensions? If you'd clicked on the PS2(ATX) link on the manufacturer's product page you would have arrived here: http://www.silverstonetek.com/techtalk_cont.php?area=en&tid=10055#1 Tells you all you need to know to be able a choose a dimensionally-compatible PSU. Upvote 0 Downvote
N Nexus2422 Honorable Nov 22, 2013 25 0 10,530 Jun 19, 2015 #3 Code: So would a 140mm be the max size compatible size? the psu i want to install in it is 200 mm : / (Super flower leadex gold 1300 watts)(and yes i meant dimensions ops... ) Upvote 0 Downvote
