What max temperature on the cpu matters? The Core temps, or the overall cpu temp for max temp specified by Amd which is 62c. Also I think the max voltage is 1.55v according to AMD OverDrive if not correct me plz.
But there are several things you should know:
-Mentioned in the link is the "max operating temperature". According to AMD, this is the Tcase max, not the TJmax. In otherwords it is the maximum temperature the case can reach, not the core.
-It is generally accepted that no one wants their AMD CPU core temperature to surpass 60*C on load
-I cannot find the actual TJmax, even on AMD's datasheets. At this temperature, the CPU will shut down. I ran tests using my old Athlon 3200+ and found it's TJmax to be between 115*C and 120*C. It still works fine and is stable.
-Overclocking the CPU reduces the TJmax temperature.
-It is generally accepted that running your CPU at high temperatures will shorten its lifespan. I have no evidence to support or deny this.
