Does Intel mean that as long as temps stay below 100C it is safe? If not, what is the max core temp for the i5-9600K and where would I find that info?
Why would you think I'd run w/o a cooler? Using a Hyper 212 RGB Black Edition.Use at least a 95 watt TDP -capable cooler, not one that came from an older i3 or i5 seven years ago...
And please don't run it without a cooler waiting on one to arrive in 2 weeks' time...
Oh, I see. You thought that maybe since the i5-9600K comes w/o a cooler, that I might not know I needed to add one. OK.I did not say you would run it without a cooler...; I merely said 'please don't' as a preventative caution.
As you mentioned no cooling solution at all, and were asking about the safety of 100C temps...; it would not be an extreme logic leap to partially worry that someone might try the 'no cooler' approach, as has been done here on the forum about once or twice per week.![]()
