It is not the actual number of fans that determine the maximum quantity you can install off of 1 fan header. It is the total current draw of the fans themselves. Typically, fan headers in motherboard are rated at 1A maximum (unless otherwise specified in the manual like the Asus MB's W_PUMP+ header and H_AMP header which can provide up to 3A).
If you fans rated at 0.3A (which is typical in case fans), then, technically, installing 3 of these fans will draw 0.9A of that 1A header. This is quite pushing it to its limit, so, for headroom, it is recommended to just install 2 of these 0.3A fans for a total of 0.6A power draw.
But if your fans are rated much less, like in your example a 0.088A fan, then, technically, you can install up...
