Maxtor basis portable 80gb hdd problem!
shikhar
103
Hello,
i have a problem with my Maxtor basis portable hard rive (80 gb).when i plug into a usb port
(2.0)it is recognised in the computer manager and it even shows a usb device connected in the task bar,but it does not show up in my computer.i previously used it in a usb 3.0 socket.please help me with this
when i open the disk management....It says....disk 1;unknown;not initialized........i tried to initialize it but the option is blurred....and the other options are,offline properties and help.....
By computer manager, I assume you mean device manager (not disk management). If this is the case, try deleting it from the device manager, then reboot the computer. See if it show up properly then.
If this doesn't work, you may have to look into recovery software such as easus partition recovery.
http://www.easeus.com/partition-recovery/
