MB biostar i945P chipset, CPU D930 changed by e740, and does not work.
Sep 30, 2018
MB biostar i945P chipset, i switched cpu d930 by e7400, and it does not work. If I update the BIOS, can I use the CPU? The socket is the same, it is the LGA 775. The MB can use Intel core 2 duo CPU, which is the case of the e7400. The BIOS is PHOENIX the version is 6.00, 28/5/2007, is there any way to change the turns to the hardware restrictions of the chipset? Microcode, bios? I'm confused, I need help.
Thank you.
