D Drugpickle Reputable Feb 19, 2014 34 0 4,530 Feb 28, 2014 #1 They fit in with the notches, but whenever I press down on them, they won't go down any further and remain loose.
ThatVietGuy Titan Nov 6, 2007 11,726 319 70,240 Feb 28, 2014 #2 Make sure the locks on the ends of the slots are open. After you put the sticks in, just press a little harder on the ends until the locks lock themselves. Upvote 0 Downvote
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 Feb 28, 2014 #3 Make sure the outer clips are off to the sides, when inserted the clips should lock themselves into place Upvote 0 Downvote
D Drugpickle Reputable Feb 19, 2014 34 0 4,530 Feb 28, 2014 #4 Nevermind, it turns out I need to push it in much harder than I thought the mobo could withstand. Thanks for the reply, though. Upvote 0 Downvote
