Question Memory overclocking failed after changing from ryzen 5 3600 to ryzen 5 5800x
Sep 15, 2023
today i got a new ryzen 7 5800x and ram speeds are sets to default 2133mhz then i set it to 3200mhz from bios witch worked fine with 5 3600 , but after with 5800x that PC gives prompt saying Memory overclocking failed
Reactions: Order 66
Sometimes it takes some tweaking to get Memory Frequencies to adjust to newer CPUs that were JUST installed in a MOBO that previously had another one so give it some time and then we'll see if I'm wrong or not..................................
Especially if you've not reset CMOS since changing CPU or updating BIOS definitely do it, then try enabling XMP for the memory. Also be sure to use the 2nd and 4th DIMM socket going away from the CPU if the mobo has 4 DIMM sockets.
Another trick is to manually set the DIMM voltage in BIOS; check memory labels or their package for the rated voltage. This is more frequently useful for getting 3600 memory to POST but can't hurt to try it with your 3200.
