Hi all,
Just built myself a new system comprising -
Ryzen 5 1600x
Corsair vengeance 3000mhz RAM - 2x8GB (cmk16gx4m2d3000c16)
AsRock b450M Pro4-F mobo (BIOS version 1.60)
Nvidia 960 (Just a stand in till I get my RX470 back from a friend)
Since building the system, I've been unable to get the RAM to go above 2133mhz. I've tried enabling XMP and setting it to 3000, 2933, 2666 and 2400mhz in the BIOS. Every one it does the restart 3 times thing and then reverts back to 2133mhz. Voltage is at 1.35v and SOC voltage at 1.15v. I've tried using Ryzen Master to alter the settings, same thing. I've tried the RAM sticks in A1/B1 and A2/B2.
The only luck I've had is if I remove one of the sticks, the remaining one will then go up to 2933mhz and boot fine. But as soon as the 2nd stick goes back in, it reboots and back to 2133mhz.
Here's a couple of pics of the BIOS settings in case it helps -
https://linustechtips.com/main/uplo...53_9.jpg.fc815c8f2a3b379aed3bff2180410b46.jpg
https://linustechtips.com/main/uplo...humb.jpg.9780d03b4ef77e62dabc962947b91928.jpg
I've checked the AsRock website and there is a newer BIOS, but that and in fact the one currently on the mobo state "*ASRock do NOT recommend updating this BIOS if Pinnacle, Raven, Summit or Bristol Ridge CPU is being used on your system. ". My CPU is a Summit ridge. I would however like to explore all other possibilities before I go changing the BIOS version though.
Can anyone offer any other solutions please as I'm currently about to start pulling out what little hair I have left
Thanks all.
Ryzen 5 1600x
Thanks all.
