Hello all, having read a few of the related THG articles, there is a few question I'd like to ask about the Memory speed and the CPU's FSB speed. (Hope these question are not too stupid to ask
1.
Using the latest p4 as an example, where the FSB is operating at 1066MHz (4*266 approx), is it better to use DDR2-533Mhz memory, than say, DDR2-333 ones? Because 533*2 = 1066
Is this kind of logic correct when aiming for optimization?
2.
Just another variation of question 1, with a P4 that operates the FSB at 800MHz, is it better to use DDR2-400, than say, DDR2-533, even though DDR2-533 has a higher speed? Because of the same reason as above, that 2*400 = 800, matching the FSB speed.
Again, is this kind of logic correct when aiming for optimization?
And finally....
3.
With the Latest Athon chipsets supporting 1GHz HyperTransport, instead of having two variables like in the P4 examples, there is now three!
With Intel:
- CPU FSB speed
- Memory speed
With Athlon:
- CPU FSB speed - which at the moment is 400MHz (2*200)
- HyperTransport speed - which at the moment is 1GHz
- Memory speed
Assuming my logic for optimization from question 1 & 2 is correct (otherwise I'll just look real stupid 😛), what is the best memory speed for an Athlon FX-55? I was thinking:
Would it be DDR400? (to match the 400Mhz FSB)
Or would it be DDR500? (to match the 1GHz HyperTransport)
Thankyou for your time
Note: question 1 & 2 assumes the usage of DDR2, where in question 3, the Athlon64 FX-55 could only work with DDR (at the moment).
1.
2.
And finally....
3.
With Intel:
- CPU FSB speed
- Memory speed
With Athlon:
- Memory speed
