S StanTheIV Commendable Jan 24, 2021 15 0 1,510 Feb 4, 2021 #1 How can I change my RAM clock speed? I've noticed it's only at 1300
rgd1101 Don't Moderator Nov 7, 2011 74,432 4,112 176,290 Feb 4, 2021 #2 what the spec on the ram ddr mean double data rate. 1300x2 is 2600. Upvote 0 Downvote
M.AGamer Reputable Feb 19, 2019 387 33 4,740 Feb 4, 2021 #3 StanTheIV said: How can I change my RAM clock speed? I've noticed it's only at 1300 Click to expand... Check what speed does your ram support and make sure you have activated the right xmp profile in bios Upvote 0 Downvote
S StanTheIV Commendable Jan 24, 2021 15 0 1,510 Apr 12, 2021 #4 So I have 2 sticks of this Apacer 2666hz ddr4 ram ( https://imgur.com/a/IkFLtwG View: https://imgur.com/a/IkFLtwG ) and it says on it that it is 2666hz, however when I checked it was at 1333 and I couldn't change it from the bios. My MB is A320m pro. Does it not support it or something? Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,432 4,112 176,290 Apr 12, 2021 #5 ddr mean double data rate. it running 1333x2 = 2666 Upvote 0 Downvote
S StanTheIV Commendable Jan 24, 2021 15 0 1,510 Apr 12, 2021 #6 thank you for your wise words Upvote 0 Downvote
