Question Memory Upgrade for a P75-A7200 Satellite
Oct 1, 2019
I have a Toshiba P75-A7200 Laptop that came with 8GB memory factory installed. I want to upgrade to the max of 32GB, was told this model has 4 slots and 2 of them each have 4GB installed, and I would need to purchase 4 sticks at 8GB each ... makes sense. Problem is I can only find 2 slots to fill which are under the removable cover. I have had this thing apart to the motherboard and still only see those 2 slots. Are there 2 more slots hidden away somewhere that I'm not able to see or are the 8GB built into the motherboard that are not removable?
P/N PSPLNU-00H004
S/N 9D018767C
P/N PSPLNU-00H004
S/N 9D018767C
You'll need to remove the whole motherboard to see the other two slots.
You can try to open it yourself but if you find that troublesome you could get a professional to do it.
Are they stacked on top of each other? Looks like they are underneath the motherboard see pictures here https://www.ifixit.com/Guide/Toshiba+Satellite+P75-A7100+Motherboard+Replacement/104099
You're correct. they're stacked on-top of each other on both sides of the board.
Excellent! It didn't look like it was possible that there was room for 2 more on the other side. Guess I know what I'll be doing tomorrow!
Thanks!
