Micro ATX and GTX 980
Ymloota
will I be able to use a Micro ATX motherboard with a GeForce GTX 980 without bottleneck. Which MicroATX motherboards would work well with the GTX 980??
the size of the motherboard has nothing to do with its ability to work with a good CPU. you can buy a micro ATX motherboard that supports an i7 and then overclock the i7 and get an absolute beast. pretty much you want a board that can support a i5 of preferably the 4000 series or newer. or at least a FX 8350.
