Micro ATX Power Supply
pjg
838
Micro ATX Power Supply will work with the ATX motherboard right???
CORSAIR SF Series SF450 450W 80 PLUS GOLD Active PFC Haswell Ready SFX SFX12V Micro ATX Full Modular Power Supply
thank you i got a little bit of a thought
Good though it is, the only problem with the Corsair SF psu is that Corsair does not supply the ATX bracket. One has to buy/order it separately.
Thermaltake and Silverstone include the ATX bracket in the box.
thank you
i have the Cooler Master HAF 912 - Mid Tower Computer Case with High Airflow, Supporting up to Six 120mm Fans and USB 3.0 do i need it
While the Corsair SFX is an excellent SFX psu, you'd be just as well off using a standard ATX psu, which will probably have a larger fan, so has the capability of running cooler and quieter and considerably cheaper.
Power Supply: Corsair - SF 450W 80+ Gold Certified Fully-Modular SFX Power Supply ($86.54 @ OutletPC)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($46.99 @ Newegg)
If you already have the SFX psu, then it's fine for use in the Haf case, but you will need that adapter, the Haf is ATX.
