Micro ATX vs ATX
Speedr269
I am debating between these two mother boards:
http://pcpartpicker.com/parts/compare/asrock-motherboard-h97mpro4%2Casrock-motherboard-h97pro4/
I have components picked for the micro ATX mobo, and i was considering an ATX mobo now, would all the components be compatible with both mobos? Should I go with the ATX or mATX?
Current build: http://pcpartpicker.com/b/92jcCJ
Back in the day, ATX was worth having because of the amount of expansion cards you'd want to install - I was never a power user, but even I had a graphics card, soundcard, USB card, TV card...others would need network cards, I/O cards and all the rest...Now, everything's so integrated on the motherboard that the vast majority of people rarely need to install anything more than a graphics card.
My last ATX board I had only a graphics card and my old soundcard installed, and then when I went to Win7 I didn't even use the latter. My latest build I just went mATX so I could use a mATX cube case. I've still got two PCI-E slots available, whether I'll ever need to use them is a another matter. It's also possible to get mATX boards that can...
I would pick neither.
H97 will not let you overclock the "K". You want a Z97 based motherboard for that.
M-ATX is good if you want a smaller case.
M-atx might also be cheaper.
Past that, there is little to choose.
If your purpose is gaming, realize that your cpu could support a much stronger card.
That is ok if you are planning on a graphics upgrade in the future.
Otherwise, look at a less expensive i5 or even a good i3 paired with a stronger graphics card.
Your CPU is K-CPU,you should pick a Z97 chips mobo,I have I5 4690K with MSI Z97 GAMING 5 and G3258 with MSI Z97 PC MATE,If you don't have enough budget,I would prefer you pick MSI Z97 PC MATE.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($209.99 @ Newegg)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard ($89.78 @ OutletPC)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($72.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($48.49 @ OutletPC)
Video Card: Asus GeForce GTX 750 Ti 2GB Video Card ($104.99 @ Newegg)
Case: Corsair SPEC-03 White ATX Mid Tower Case ($29.99 @ Newegg)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($13.99 @ Newegg)
Wireless Network Adapter: TP-Link TL-WN822N 802.11b/g/n USB 2.0 Wi-Fi Adapter ($12.99 @ Amazon)
Case Fan: Corsair Air Series AF120 Quiet Edition (2-Pack) 39.9 CFM 120mm Fans ($24.15 @ NCIX US)
Total: $592.36
Generated by PCPartPicker 2014-11-26 20:44 EST-0500
My last ATX board I had only a graphics card and my old soundcard installed, and then when I went to Win7 I didn't even use the latter. My latest build I just went mATX so I could use a mATX cube case. I've still got two PCI-E slots available, whether I'll ever need to use them is a another matter. It's also possible to get mATX boards that can support two GPU cards.
So to answer your question:
- if you're sure you'll need several cards in future, get ATX
- if not, choose your case first, and if it's mATX get mATX
- otherwise, if you've an ATX case, get ATX if it's only marginally more expensive than mATX for otherwise the same model.
Windows 7 OS
For the power supply i'm not sure which to go with, since i don't plan on overclocking and installing another video card, should I go with a single 12V rail?
http://www.evga.com/Products/Product.aspx?pn=100-B1-0500-KR
http://www.evga.com/Products/Product.aspx?pn=100-B1-0600-KR
http://www.evga.com/Products/Product.aspx?pn=120-G1-0650-XR
Build so Far:
http://pcpartpicker.com/parts/partlist/
You need to click on export/markup to share your build.
Forget EVGA B1 or G1 series. Go for EVGA B2 750W or G2 series.
wouldn't that be overkill?
PCPartPicker part list: http://pcpartpicker.com/p/ZtkXFT
Price breakdown by merchant: http://pcpartpicker.com/p/ZtkXFT/by_merchant/
CPU: *Intel Core i5-4690 3.5GHz Quad-Core Processor ($219.99 @ NCIX US)
Motherboard: ASRock H97 PRO4 ATX LGA1150 Motherboard ($80.54 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($75.98 @ OutletPC)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($69.99 @ Newegg)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($14.98 @ OutletPC)
Case Fan: Corsair Air Series AF120 Performance Edition 63.5 CFM 120mm Fan ($14.03 @ OutletPC)
Keyboard: Razer Blackwidow Ultimate 2014 Wired Gaming Keyboard ($94.99 @ Amazon)
Total: $753.97
Yes it is.
Either these psu will be fine then for a future single gpu upgrade from a GTX 750Ti:
http://pcpartpicker.com/part/evga-power-supply-100b10600kr
http://pcpartpicker.com/part/seasonic-power-supply-s12ii620bronze
http://pcpartpicker.com/part/xfx-power-supply-p1650xxxb9
A 750 Ti requires no more then a 400w. I'm not to crazy about the EVGA power supplies I like the XFX better.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
