M matthew.sommerfeld2015 Dec 4, 2018 9 0 10 Jan 14, 2019 #1 For my i3 4170 processor is it better to get a micro ATX or the smaller ITX.
Solution Ralston18 Jan 14, 2019 Will offer the following "starter" links: https://techguided.com/micro-atx-vs-mini-itx-vs-atx/ Older link but from this Forum: http://www.tomshardware.com/answers/id-3368399/mini-itx-matx.html You can easily find other similar links and there may be additional responses to your post. I would leans towards the micro ATX - just to to have some room for growth.
Ralston18 Titan Moderator Oct 11, 2014 37,848 3,977 146,290 Jan 14, 2019 #2 How will you be using the computer? What are the end use requirements or expectations? Do you plan to make other upgrades in the future? Upvote 0 Downvote
M matthew.sommerfeld2015 Dec 4, 2018 9 0 10 Jan 14, 2019 #3 It will be a bit of a gaming pc nothing serious. Want to play games at medium to high setting a 50-60 fps. I will not be upgrading for awhile. Upvote 0 Downvote
Ralston18 Titan Moderator Oct 11, 2014 37,848 3,977 146,290 Jan 14, 2019 Solution #4 Will offer the following "starter" links: https://techguided.com/micro-atx-vs-mini-itx-vs-atx/ Older link but from this Forum: http://www.tomshardware.com/answers/id-3368399/mini-itx-matx.html You can easily find other similar links and there may be additional responses to your post. I would leans towards the micro ATX - just to to have some room for growth. Upvote 0 Downvote Solution
T TJ Hooker Titan Ambassador Apr 15, 2014 11,566 1,728 72,390 Jan 14, 2019 #5 Do you have a case in mind already, or will you choose that based on the mobo you decide on? Unless you really want/need a small form factor PC, I'd go with the micro ATX. ITX typically cost more and you get less ports/connectors. Upvote 0 Downvote
