Microphone creating a high pitched noise
Juku80002
6
Hello,
My microphone has started to create a high pitch noise. It doesn't stop no matter if the microphone is muted or not, although it does stop when I unplug the microphone. I do believe that the problem is not in the microphone itself, as when I plug it into my laptop, the high pitch noise is nowhere to be heard. I am using a headset, the microphone is not part of the headset itself. I have also tried to move cables away from audio cables with no success to getting rid of the noise.
What could I do to solve this issue?
Thanks
Found a solution to my problem after putting hours into it. The problem ended up to be the realtek audio driver downloaded from Asus (as I have an Asus z170 sabertooth mark 1). I simply uninstalled it and downloaded new Realtek audio drivers from Realtek's own site. The problem was immediately solved.
