Hello all the computer masters,
I recently buy a headset with microphone with the Pink/Green jacks
The earset part of them works fine, but the mic part doesn't at all.
The system doesn't even pick up that a mic is plugged in. I have tried
both the front and back jacks of my PC with the same issues. Under the
Recording Tab in Sound it reads, NO audio devices are instaled, and I
have the Show disabled devices checked. My biggest issue is I use
gtalk and can't talk on it with this issue.
I followed this step>>>> 1. Right click on the
volume icon in the system tray and then click "Recording devices".
2. Right click on the blank place in the popped up window and then
select "Show Disabled Devices" and "Show Disconnected Devices".
3. Right click on Microphone and then click "Enable".
4. Highlight the microphone and then choose "Set as Default Device".
5. Click Apply.
6. Select Microphone and click on Properties.
7. Click on Levels tab. The default Microphone Boost is set to 0,
increase it.
but after Right click on the blank place in the popped up window and
then select "Show Disabled Devices" and "Show Disconnected Devices".I
do not find any Microphone. please help me!!!!!!!!!!!!
Thank you ahead of time for any help.
please reply with help. it is needful.
Thanks & regards,
Subhankar Kundu.
5. Click Apply.
increase it.
Thanks & regards,
Subhankar Kundu.
