Microphone not working
Netherzapdos
33
So i have a Realtek HD Audio Microphone Device(?) installed and this is where i edit my mic.
I don't really edit my mic too much besides the amount of decibles, and right now it's at +30dB
But after sometime the mic randomly stopped working. It works at times but i have to like adjust the mic plug around to find that "soft" spot and get the mic working, now it's doesn't work at all.
I feel like the best solution is a reinstall of the audio device but i need some help.
So if i do this correctly, i go to Device Manager, go to Sound, Video and Game Controllers, right click Realtek High Definition Audio and press Uninstall.
Next, can anyone confirm if this is the right link to download the drivers? And which one should i download? http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Thanks so much, like please i really need this ^^
I did that and it didn't fix the problems. I am assuming you might be having the same issues I am where it just isn't picking up the mic but the mic says it is connected and nothing needs to be updated. The program won't even load for me under program files either.
