Question microphone not working!
Dec 25, 2018
14
Hello,
i got a Razer Kraken PRO v2 and the sounds works just as it should.
but the microphone is not!
when i go to discord i can see my microphone is active but i am not talking nor there are any other sounds in my room it is very quiet dead.
HELP ME PLEASE! I just wanna be able to play again with my microphone.! :C
NOTE: If i click on ''Lets Check'' i can only hear statics!
Lets Check is to hear what the other should hear when i talk.
If you are running a recent build of Windows 10, then microphones are disabled by default and you have to give the application permission to use it. Open your settings, go to Privacy and go to Microphone under App Permissions and allow Discord access to the microphone.
This is the cpu sub forum bro. There has to be a better place to get an answer....
i am very sorry i am very desperate i have most of my problems solved here! :c
i cant find disord under ''App Permissions'' > Microphone.
