Microphone suddenly not working, realtek HD audio.
Asfalimtus
12
Microphone stopped working, found it out when i tried to make a call on Skype, until then it always worked properly.
I fiddled with settings and even tested another microphone which didn't work as well.
I reinstalled windows completely, installed up to date drivers for motherboard and everything else I use regularly but nothing helped.
I tried all the tricks i found online:
put mic volume to full and add 20dB boost,
"seperate all input jacks as independent input devices" in realtek audio manager,
disabled front input jacks,
deleted realtek audio manager and tried using microphone with basic microsoft drivers,
nothing worked.
If i turn on playback for microphone I can hear static. Even when playback is turned off it is possible to record "noise" by moving microphone around or touching it.
This computer had windows vista/7 and 8 installed and everything (except front audio panel that pretty much never worked) worked fine till yesterday.
I'm not sure but I think that my sound card is integrated so I'm asking if there is something i could try other than buying new motherboard?
System Information
Time of this report: 10/16/2013, 19:19:57
Machine name: TURBOFOLK
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_rtm.120725-1247)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: EP43-S3L
BIOS: Award Modular BIOS v6.00PG
Processor: Pentium(R) Dual-Core CPU E5200 @ 2.50GHz (2 CPUs), ~1.9GHz
Memory: 4096MB RAM
Available OS Memory: 4094MB RAM
Page File: 1541MB used, 6137MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1458A002&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6662 (English)
Driver Attributes: Final Retail
WHQL Logo'd: n/a
Date and Size: 6/19/2012 09:54:20, 4065296 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sound Capture Devices
Description: Microphone (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
Description: Realtek Digital Input (Realtek High Definition Audio)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x0
Format Flags: 0x0
full dxdiag info file:
http://www.fileswap.com/dl/98QiKHmuOX/
Thanks.
Dude im sorry to say this, but i think that the microphone port on your mobo is not working, did you maybe try using a usb microphone, cause its definitely not the driver, and definitely not the microphone if you tried 2 of them, if you know somebody that has a usb microphone, try that out, if it works you'll know for sure.
