Question Microsoft Edge crashed and refuses to start again
pandapoodle
4
I opened a google document tab on Microsoft Edge which responded by immediately crashing without error message and now it refuses to start again. I attempt to start it but literally nothing happens. No Window. No error. Nothing.
I have tried:
1) Rebooting: Issue persists.
2) Repairing through the App settings: It goes through the motions but issue persists, even after more reboots.
3) Uninstalling I cant due to an error pop-up: "There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personell package vendor."
4) Downloading and Installing Edge again: It goes through the motions, but issue persists.
5) Venturing into the AppData/Local/Packages/ and removing the Microsoft Edge folders there: It did not seen to have any effect so I put them back.
If anyone has a good idea I am all ears. I really want to avoid re-installing the entire OS over this however.
right click start button
choose powershell (admin)
copy/paste this command into window:
Repair-WindowsImage -Online -RestoreHealth
and press enter
Then type SFC /scannow
and press enter
Restart PC if SFC fixes any files as some fixes require a restart to be implemented
First command repairs the files SFC uses to clean files, and SFC fixes system files
SFC = System File Checker. First command runs DISM - https://docs.microsoft.com/en-us/windows-hardware/manufacture/desktop/what-is-dism?view=windows-11
