Question Microsoft Surface Pro 9 not charging via a USB-C 65W PD charger ?
salilsurendran
112
I purchased this 65 W USB-C PD Charger to charge My Microsoft Surface Pro 9 and this worked till recently, always fast charging my laptop. However, since the latest update, when smart charging was introduced, my 65W USB-C PD charger is no longer charging my Surface Pro 9. I have to hit the power button and restart the Surface Pro 9 for it to recognize that it is connected to a charger and start charging. Once I disconnect the PD charger and connect it again, the Surface Pro 9 no longer recognizes the charger and doesn't charge.
However, the original Surface Power Adapter always works and always charges my Microsoft Surface Pro 9. I believe this problem was introduced by smart charging and when I try to disable smart charging I am unable to do that as shown in the attached image. When I go to the Surface app and then go to the battery and recharging section, it says smart charging is already paused and the option to charge to 100% is completely disabled. How do I fix this?
is only one port of the charger used while charging the laptop? don´t plug in any other cable, even if not connected to a different device
are you using usb-c to usb-c cable connection to charge?
try a different usb-c to usb-c cable
rma the charger
Yes, only one port of the jar of the surface pro 9 is charged via the USBC charger. The other port is not in use. The charger used to do fast charging using the same USBC cable. So I don't believe that there is anything wrong with the cable or the PD charger. The issue is with one of the Windows 11 updates that introduce smart charging
