Mid-Range Build for my dad. (First Build)
Cheeseter
5
Hello all! My Name is D and this is my first post in this forum and I'm planning on staying. Heard a lot of great things about you guys. I'm building a system for my dad and just wanted to make sure that everything will work. This is my first build I have ever done by myself, so just wanting to be safe. Thanks!
Approximate Purchase Date: Today or tomorrow
Budget Range: Under USD $2,000
System Usage from Most to Least Important: Transferring pictures and files/Word, Excel/Web Browsing
Parts Not Required: keyboard, mouse, monitor, speakers
Preferred Website(s) for Parts: newegg.com
Country of Origin: USA
Parts Preferences: Intel and Nvidia
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1920x1080
Motherboard: MSI P67A-GD65 (B3) LGA 1155 Intel P67
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130574
CPU: Intel Core i7-2600 Sandy Bridge
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115071
RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
GPU: GIGABYTE GV-N26UD-896M REV2.0 GeForce GTX 260 896MB 448-bit GDDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125391
PSU: CORSAIR Enthusiast Series CMPSU-850TX 850W ATX12V v2.2 / EPS12V v2.91 (Got 850W to be safe when he upgrades this system later)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
SSD: Corsair Force Series GT CSSD-F120GBGT-BK 2.5" 120GB SATA III
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233191
Optical x2: Sony Optiarc Black SATA Model AD-726Ss-0B LightScribe Support
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118040
Card Reader: Rosewill RCR-IC001 40-in-1 USB 2.0 3.5" Internal Card Reader w/ USB Port
http://www.newegg.com/Product/Product.aspx?Item=N82E16820223103
HDD x2: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Case: COOLER MASTER Centurion 5 CAC-T05-UW
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119068
OEM Version of Win7 Home Premium 64-bit
Thanks for looking this over! :)
If you have absolutely no need for overclocking, it's safe to drop down to a i5-2400 and a H6x motherboard. However, you should really drop down to at least a i5-2500k because the $100 difference isn't justifiable unless your father will be doing 3D rendering work. You can find G.Skill Ripjaws Series ram for $65. You don't need 850W for power supply. 400-500 is more than enough. I will go for 650-750 if he plans to do SLI. You should get the Samsung Spinpoint F3 instead. They have good performance and also 1TB each.
Check this link: http://www.hwcompare.com/5818/geforce-gtx-260-vs-radeon-hd-6770/
There's more energy efficient graphic cards if you're interested.
Thanks for that, filled it out :)
Overall the build looks good and I don’t see any real problems. I would say that you are a little overkill on the power supply take a look at this tool it is very good to help you find the low end on the power supply that you need http://extreme.outervision.com/psucalculatorlite.jsp. Also what are going to be doing with this system? Unless you are going to be doing a lot of video/audio type work you might find that you are better of stepping down to the Intel® Core™ i5-2500.
Christian Wood
Intel Enthusiast Team
For the CPU, he told me he wanted the best, and is willing to pay the extra money for it.
I got him a 850W PSU so he wouldn't have to buy a new one when he upgrades this rig in 3-5 years. And when he upgrades, he will be using a SLI config. With this in mind, would it be safe to go down to the 650-750 range?
The RAM I got is only 1.5v, which is why I picked it.
And the WD drives are SATA 6.0GB/s and have a 64MB Cache.
Lastly, I want to stay Nvidia because that's what we've used and I just like them better 😉
Coming from you and wintermint I dropped the PSU to a 650W.
With the CPU, my dad said he wanted the best in this price range and is willing to pay for it, so that's why I got him the i7-2600. At times he does do lots of video editing, so I don't think it will all go to waste.
Thanks all you guys for the help!! 😀
"System Usage from Most to Least Important: Transferring pictures and files/Word, Excel/Web Browsing"
But, he will upgrade to SLI in 3-5 years?
It looks like he just wants a basic a desktop, and you want to build him a powerful gaming PC. You could easily build him a decent office PC for under $1000.
