[SOLVED] Mid-Range PC Build/Advice
poignant
15
Hey all,
I was wondering if I can get some advice with some PC components. I am currently slowly assembling some components for my new mid-range PC, with the GPU being the limiting factor. Since Black Friday is coming up, I need some advice on some parts so I can be on the lookout for if there is any "deal" on them. I do live near a Micro Center. I mainly plan on playing on 1080p and maybe sometimes 1440p and mainly play MMORPGs.
My list so far- PC Part Picker
So far I only have a CPU, mobo and storage. The CPU that I got is a i7-10700K 3.8 GHz and was recently given a Asus ROG STRIX Z590-E and WD Black SN750 SE 1TB x2 by a friend.
For my GPU, I am planning on going with a 3060Ti or 3070, depending on what I am able to find. CPU cooler I was planning on going with a Noctua since my old PC (over 8 years ago) had one and didn't have a problem with it. But of course I am always open for suggestions.
Looking on advice on specific components to look for, specifically a RAM that is compatible with my mobo. A list of components I should be looking for would be most appreciated! Also, I am looking to spend about $1,500 USD with ~200-300$ wiggle room. I don't need peripherals or OS in the build.
https://www.newegg.com/super-flower-leadex-iii-bronze-sf-650r14he-650w/p/1HU-024C-00017
Super Flower Leadex III Bronze PRO 650W 80+ Bronze Modular Power Supply $89.99
https://www.newegg.com/be-quiet-shadow-rock-3-shadow-rock-2/p/13C-001F-00037
be quiet! Shadow Rock 3 CPU Cooler $49.90
https://www.amazon.com/TEAMGROUP-T-Force-Vulcan-3200MHz-Desktop/dp/B07T637L7T/
TEAMGROUP T-Force Vulcan Z DDR4 3200MHz 16GB Kit (2x8GB) CL16 $54.97
https://www.amazon.com/dp/B07GCL6BR4
Intel 660p Series M.2 2280 1TB PCIe NVMe 3.0 x4 3D2, QLC Internal SSD $79.99
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1311&_nkw=rtx+3060+ti&_sacat=0...
