Mid-tower case for two 280mm radiators.
Eximo
Ambassador
Since radiator compatibility requires looking at pretty much every case, I thought I would reach out and see what the community recommends.
Looking for suggestions for a mid-tower case, would settle for a smallish full tower as well, that can fit a pair of 280mm radiators. I lean towards plain styling. Kind of switching to an all black or black/white build. Cost is pretty flexible, probably under $200, not opposed to glass, but it would have to be pretty compelling.
Proposed components:
i7-7700k
Z class 200 series board - ATX
Likely Corsair 2x8GB LPX DDR4 for the shorter heatsinks
Components already owned:
H240-X (original) integrated pump/reservoir/radiator
EVGA Gaming SC ACX 3.0 GTX 1080 - XSPC Razor full cover water block
Corsair RMx 850W - I will look into custom cabling after a first run of the build.
having just done a build in the enthoo luxe--my first white case
have to say its great looking in white
theres also a tempered glass version now--though not in white yet--if you fancy the glass side panel
it should be possible to fit 2 x 280mm rads in this with some thought
though at the moment only got 1 x 280mm in there as havent got the block for my new gtx1070 yet
