Midi ATX with ATX motherboard
Jun 13, 2018
6
Hi guys!
I would normally be able to Google this one, but there is very little information on "Midi ATX" cases and I can't seem to find an answer.
I currently own this Vibox Tactician case, which is labelled as midi ATX:
https://www.amazon.co.uk/Vibox-Tactician-Desktop-Computer-Temperature/dp/B00CRETKFS
I'm going to buy a new motherboard, I want to buy this ATX motherboard:
https://www.amazon.co.uk/dp/B06XMXVMCH/?tag=pcp0f-21
I don't know if the motherboard will fit inside a midi ATX case, could anyone confirm or deny that ATX motherboards fit inside midi ATX cases?
Thank you for reading!
Midi is supposed to be an mATX case that supports full sized ATX boards, however based on some reviews, it does not.
I would suggest getting a better case.
There isn't much info about "Midi ATX" because that actually stands for mid-ATX which has been the standard for 15+ years (basically since floppies, zip-drives, tape drives and most other types of consumer removable electro-mechanical storage have fallen out of favor, eliminating the need for Full-ATX's extra drive bays) so nobody bothers with the 'mid' anymore.
