Question Minecraft Low Fps
Jan 25, 2021
I have an RTX 2060 and an i7 8700 and I only average about 80-100 fps on Minecraft with Optifine.
I don't know if I'm supposed to get more because I saw this guy on youtube that got his fps up to 800 and we had the exact same CPU and GPU.
You should be getting way more FPS than that.
Especially on Optifine.
What is your render distance set to?
Any shaders?
Try lowering other settings like particles,quality,etc..
Also disable any background apps.
My render distance is set to 8 and I don’t use any shaders, I also lowered my settings but it didn’t make a huge difference. Usually when I play, I don’t have anything running in the background.
Latest posts
