https://it.pcpartpicker.com/b/t8J8TW
Case Thermaltake Core V1 - I always wanted a cube pc. So I started the build by getting this case. Front 200mm fan is impressive. The layout and quality are amazing.
Motherboard MSI Z270I - mini-itx motherboard to fit the Thermaltake case. From specs, powerful and good for OC.
CPU I5 7400 3.00GHz Kaby Lake - decent price and performance for a mid range gaming pc. Would not spend more than 200 Euros on a CPU.
Video MSI RX 480 Gaming - one of the best performance price ratio. RX 580 was just released, but not too much different. It was on sale so I got it for my build. It seems huge for the case, but fits perfectly. I had to remove the case front to install it, but it was very easy. In idle the temperature is 33 ° C, on load 73 ° C. Added a magnetic filter in front of the two large fans.
RAM Corsair Vengeance RGB 16GB DDR4 3000MHz CL15 Dual Channel Kit - they look very nice.
CPU Cooler Noctua NH-U12S - too tall for this case, but I got it anyway. I drilled holes in the case plastic top panel. See pictures. It keeps the CPU at 36 ° C in idle and 53 ° C in load.
