Mixed DDR2 5300 and 5400 system Input plz
TKolb13
25
I got ahold of 2 gigs of corsair value select 5300 and i put it in my new system. Problem is I have 2 gigs of Cosair 5400 in it already. At post the bios says 4gigs but in windows it says I have 2813 gigs any Ideas? Should I take the 5300 out?
Specs.
e6600
Evga 680i Sli
Evga 8800 gxt
150 Maxtor Raptor
2 gigs 5300
2 gigs 5400
Is this why on my system info it says 3.25GB memory? I just bought another 2GB kit to total up to 4GB....for my games. At posting screen it says 4GB.
Mikeny your having the same problem? well that makes me fell better... anyone have any thoughts on why?
Thanks
You haven't said whether you're using XP or Vista. Someone has already pointed out that the inability of XP to access the entire 4GB of installed memory is a known design limitation.
-john
Yea 32 bit operating systems can handle a "maximum" of 4 GBs of RAM. But for some reason Windows XP will only handle about 3.25 GB, everybody with XP and 4 GBs of RAM has the same issue. I don't know the technical reason for this but you're not alone.
Vista Ultimate...
Apologies. Didn't see this the first time.
I googled the question. This may be of interest: Maximum Memory in 32-bit Windows Vista. The gist of it is that the actual amount of memory you can access depends on how Windows allocates your 4GB address space. Some addresses can't be used to access memory because apparently they are mapped to hardware.
I thought the 4GB problem would be fixed by Vista, but it looks like I was wrong.
-john
