Hey guys. I will be building my first custom loop in July, and I am looking at push/pull configurations for the two radiators I will be using. Too be honest, two radiators is probably a bit of overkill, especially as they are 360mm ones ( either the Corsair XR5 or the XR7, or possibly one of each. looking into what will fit in my case ). For the fans, I was going to use Corsair QL120 on one, with 41.6 CFM as the pull side, and either the BykSki CF-APRBW-V3 with 64.8 CFM or the ID-Cooling NO-12015-XT with 54.6 CFM as the push. For the second radiator, it would be Corsair LL120 with 43.25 CFM as pull and either the Bykski or ID-Cooling fans as push. One radiator would be intake, the other would be exhaust. The case I will be using is the Lian Li O11D Evo, which is why I am worried about the sizes of the rads. The XR7 should fit at the top ( it would be the exhaust ) while the XR5 would, I think, be better for the intake. it would be side mounted.
Thanks in advance for any help!
Chesh
Chesh
