S seanpuge May 11, 2018 2 0 10 May 24, 2018 #1 So... I was planning to get a 1030 but I found this 1050 mini because ( I think ) it will last longer so just a budget mobo and cpu for it ( I still don't have the budget though ) so will this be worth in late 2018?
Solution camieabz May 24, 2018 It will be double the 1030 (on average benchmarks) - http://gpu.userbenchmark.com/Compare/Nvidia-GTX-1050-Ti-vs-Nvidia-GT-1030/3649vsm283726 A budget, entry-level gaming system I specced recently (older games, or low to med settings) - https://uk.pcpartpicker.com/list/WwnXyX Worth it? Depends what you want to run. If you're on a tight budget and want top-end gaming, you're going to be disappointed.
arif1752002m4a1 Honorable May 16, 2018 818 34 11,740 May 24, 2018 #2 For this system. You can go cheaper. Like here Processor.......intel core i5 7400 Motherboard... Gigabyte b250m gaming. Ram................2x8GB kingston hyperx ddr4 2400mgz.. Upvote 0 Downvote
camieabz Splendid Jan 29, 2001 8,709 4 31,815 May 24, 2018 Solution #3 It will be double the 1030 (on average benchmarks) - http://gpu.userbenchmark.com/Compare/Nvidia-GTX-1050-Ti-vs-Nvidia-GT-1030/3649vsm283726 A budget, entry-level gaming system I specced recently (older games, or low to med settings) - https://uk.pcpartpicker.com/list/WwnXyX Worth it? Depends what you want to run. If you're on a tight budget and want top-end gaming, you're going to be disappointed. Upvote 0 Downvote Solution
