Mobo choose help!
Dec 8, 2018
Hello
I need help with choosing mobo for my first budget ryzen build. I am planing to build R5 2600 and AMD B450 mobo but dont know which shoold I choose. Where I live there are few b450 mobos : MSI B450 GAMING PLUS , Gigabyte B450 AORUS ELITE , ASROCK B450 PRO 4 and ASROCK AM4 B450 Fatal1ty GAMING K4.
I've read some reviews but couldnt find a solid one. Some are saying gigabyte have bad VRM's and heat sinks ,MSI bad BIOS and so on. For now I will use the stock cooler of the CPU but in future when I get some good cooler I might do some, but not too heavy overclocking (reach the speed of the X version chip).
My build :
CPU AMD Ryzen 5 2600
Sapphire AMD PCX PULSE Radeon RX 580 8GB
DIMM 8GB DDR4 3200MHz Kingston HyperX XMP Predator x1stick - I will upgrade one more soon couse I am on budget
SSD M.2 Samsung NVMe 970 EVO 250GB PCIe 3.0 x4 - will upgrade ssd 500gb
PSU - Have not choosed yet couse here we have low quality brands like Gembird,Deepcool ,Sharkoon ... probably will be 500-600W 80+bronse ... some recomendations ??
Monitor 24" Philips 246E9QDSB/00 IPS with AMD FreeSync, Scanning Frequency 50 - 76 Hz
I am looking forward to your feedback and opinions of my biuld.
Thnaks.
Out of that list either of the asrock boards, they have solid vrm setups, the cheap msi & Gigabyte boards are lacking in that respect.
You don't want to be running a rx 580 on a cheap psu though seriously, it's a demanding card.
The absolute minimum on quality & wattage would be a corsair cx550 or coolermaster masterwatt 550.
I found in one store Cooler master masterwatt 550 http://www.coolermaster.com/powersupply/80-plus/masterwatt-550/ is it good one ?The corsair is only available in 750w so thats overkill.
In my budget range and availability I found are
Cooler Master MWE 650W 80Plus Bronze,
Cooler Master MasterWatt Lite 600W 80Plus,
EVGA 500 B1, 80+ BRONZE 500W,
EVGA 550W B3 80 Plus Bronze,
Seasonic S12II 520 SS-520GB 520W 80+ Bronze but its quite out of my budget.. is it woth extenging it for this psu ?
