B Bazyks Reputable Dec 21, 2015 40 0 4,530 Apr 30, 2018 #1 How would you guys close this gap?i put an acrylic window and it isn't a tight fit.Would leaving it like this affect dust filtrering? https://imgur.com/a/DAc0QZo
RememberThe5th Illustrious Jul 30, 2014 6,995 170 41,140 Apr 30, 2018 #2 I think putting an foam/sponge type glued acrylic window should be pretty? Upvote 0 Downvote
Gam3r01 Titan Jan 12, 2013 25,414 974 115,440 Apr 30, 2018 #3 You probably should have bought the correct size piece of material in the first place. Upvote 0 Downvote
