Modeling and rendering pc build for a novice. (Update)
Falconex
17
Well I am going to take some modeling and rendering classes, and ill be in the need to have decent workstation. I have around 2500 dollars.
I built a gaming pc (that I still use) and I know I need to spend a little bit more on the gpu than the cpu, but with this build I dont have a slight clue. Ill be using the most popular programs,but I will probably use maya more regularly. I dont intend to spent a lot of cash on storage since I already have an old ssd, and my case will be a mid size case.
I also dont know wether to buy an nvidia quadro or an amd firepro.
Thankyou
Update
So I made up my mind now, I will getting a 4070k with a firepro but I still need a motherboard, In my gaming rig I use a gigabyte ud3h (wich is a very reliable motherboard), but I could get a smaller motherboard with an smaller case.
Are small factor motherboards more expensive than normal size motherboard, do they have the same price to performance ratio?
The results section of this article has some good stuff. http://www.pugetsystems.com/labs/articles/AutoDesk-Maya-2014-Professional-GPU-Acceleration-509/
I think the W5000 is kind of the sweet spot for performance vs price.
I would go at least an i5 if not an i7.
haswell cpu 4070k overclocked to 4.2 ghz
EVGA gtx 780 superoverclocked
samsung 840 ssd
gigabyte ud3h motherboard
