Modem Problems!
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
Over the past few weeks I have gone from a consistant 50K connection
down to a 37K connection. I even took and reinstall everything from
scratch and the same problem exist. If I take from an inital boot I can
usally get a 45K connection but after that I get when trying to connect
is a disconnect and the dialing. The modem is Gateway V.92 PCI Soft
Modem R1 (Palmer) [Part #6002118] I have tried all three driver
suggested nothing make a difference. Getting a lot of disconnect too.
Have tried these drivers 9519160_XP_2K, 9520523_xp_2k and 9523470 with
no luck.
The only upgrade that I have made lately is a Belkins USB card though
this issue started before adding the device. I did have problems with
the 9519160_XP_2K drive though it keep causing my computer to reboot
after using it. Since I have the 9520523_xp_2k no more reboots but still
the low connection at 27 to 37K.
Thanks,
Ron
Here is my current configuration:
Operating System System Model
Windows XP Professional Service Pack 2 (build 2600) Gateway E-4600 4000762
Processor a Main Circuit Board b
1.90 gigahertz Intel Pentium 4
8 kilobyte primary memory cache
256 kilobyte secondary memory cache Board: Intel Corporation D850GB
AAA49507-904
Bus Clock: 100 megahertz
BIOS: Intel Corp. GB85010A.15A.0046.P13.0108201551 08/20/2001
Drives Memory Modules c,d
671.00 Gigabytes Usable Hard Drive Capacity
488.29 Gigabytes Hard Drive Free Space
TDK CDRW5200B [CD-ROM drive]
TDK DVDRW840G [CD-ROM drive]
3.5" format removeable media [Floppy drive]
Maxtor 4A300J0 [Hard drive] (300.00 GB) -- drive 1, s/n A80VM9HE, rev
RAMB1TV0, SMART Status: Healthy
Maxtor 6Y250P0 [Hard drive] (251.00 GB) -- drive 2, s/n Y614XA0E, rev
YAR41BW0, SMART Status: Healthy
WDC WD1200BB-50CAA1 [Hard drive] (120.03 GB) -- drive 0, s/n
WD-WMA8C2548307, rev 17.07W17, SMART Status: Healthy 1280 Megabytes
Installed Memory
Slot 'J7J1' has 512 MB
Slot 'J7J2' has 512 MB
Slot 'J8J1' has 128 MB
Slot 'J8J2' has 128 MB
Local Drive Volumes
c: (on drive 0) 120.02 GB 108.52 GB free
d: (on drive 1) 52.44 GB 16.53 GB free
e: (on drive 1) 247.56 GB 247.46 GB free
h: (on drive 2) 125.49 GB 90.22 GB free
i: (on drive 2) 125.49 GB 25.57 GB free
Network Drives
Users Printers
local user accounts last logon
Ronald D. Brimmer 5/3/2005 12:12:30 PM (admin)
local system accounts
Administrator never (admin)
Guest never
HelpAssistant never
SUPPORT_388945a0 never
Marks a disabled account; Marks a locked account hp officejet k
series on DOT4_001
hp officejet k series fax on DOT4_001
Controllers Display
Standard floppy disk controller
Intel(r) 82801BA Bus Master IDE Controller
Primary IDE Channel [Controller]
Secondary IDE Channel [Controller] RADEON 9600 SERIES [Display adapter]
RADEON 9600 SERIES - Secondary [Display adapter]
Samsung SyncMaster [Monitor] (15.7"vis, s/n HVAW201185, February 2003)
Bus Adapters Multimedia
WinXP Promise Ultra133 TX2 (tm) IDE Controller
Intel(r) 82801BA/BAM USB Universal Host Controller - 2442
Intel(r) 82801BA/BAM USB Universal Host Controller - 2444
NEC PCI to USB Open Host Controller
Standard Enhanced PCI to USB Host Controller Creative SB Live! Series
(WDM)
Creative SBLive! Gameport
Logitech Microphone (Pro 4000)
Unimodem Half-Duplex Audio Device
Communications Other Devices
GTW V.92 Voicemodem
1394 Net Adapter
RAS Async Adapter Texas Instruments OHCI Compliant IEEE 1394 Host
Controller
APC Battery BackUP
American Power Conversion USB UPS
HID-compliant device
USB Human Interface Device
Hewlett-Packard OfficeJet K80 Scanner
Logitech QuickCam Pro 4000
Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
HID-compliant mouse
Microsoft PS/2 Mouse
Logitech USB Camera (Pro 4000)
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
Have you tried this machine on any other phone lines or at anyone else's
house? There could be issues outside of the box that are degrading your
modems performance. The last mile for dial-up connections has the greatest
impact on the actual connection speed. Something so simple as a some heavy
rain or even just high humidity can case problems.
KC
"RDBrimmer" <RDBrimmer@netscape.net> wrote in message
news:N9Ude.694837$w62.623127@bgtnsc05-news.ops.worldnet.att.net...
> no luck.
> Thanks,
> Ron
4000762
> AAA49507-904
> Installed Memory
> Local Drive Volumes
> Network Drives
> Users Printers
> Guest never
> HelpAssistant never
> series on DOT4_001
> Controllers Display
> (WDM)
> GTW V.92 Voicemodem
> 1394 Net Adapter
> Controller
> APC Battery BackUP
> HID-compliant mouse
> USB Root Hub
> USB Root Hub
> USB Root Hub
> USB Root Hub
> USB Root Hub
No I have not tried it elsewhere, I think that I am going to buy a new
modem just to have one hand. Any suggestions as long as voicemodem use
internet calling Net2Phone and Skype. Any pro's and con's of USB modem.
Ron
> KC
>>no luck.
>>Thanks,
>>Ron
> 4000762
>>AAA49507-904
>>Installed Memory
>> Local Drive Volumes
>> Network Drives
>>Users Printers
>> Guest never
>> HelpAssistant never
>>series on DOT4_001
>>Controllers Display
>>(WDM)
>>GTW V.92 Voicemodem
>>1394 Net Adapter
>>Controller
>>APC Battery BackUP
>>HID-compliant mouse
>>USB Root Hub
>>USB Root Hub
>>USB Root Hub
>>USB Root Hub
>>USB Root Hub
I'd bet good money it is NOT anything in the machine. It is a bad phone
line or switching card in the telco office. I am having a similar
problem here. The phone has some background static but VERY
intermittent. The poor line has dropped my 50,666 normal connection down
to 46,000 or lower. I know the problem is in the underground line but
the phone co. doesn't show a problem when they test the line. Mid winter
there was a lightning strike nearby that took out the neighbors phone
but they say that couldn't be a problem... rightttt..
To make SURE it isn't in your home wiring connect up the modem input
line with the telco interface on the outside of your house. If your
connection improves the wiring in your house is suspect. If not it is in
the line somewhere else. If it is still there, get on the phone and
complain to the telco office that you keep hearing noise on the line,
crunch some potato chips in the background if needed to make them hear
it.
Steve Williams
can
connect
> no luck.
still
> Thanks,
> Ron
4000762
> AAA49507-904
> Installed Memory
> Local Drive Volumes
> Network Drives
> Users Printers
> Guest never
> HelpAssistant never
k
> series on DOT4_001
> Controllers Display
adapter]
Series
> (WDM)
> GTW V.92 Voicemodem
> 1394 Net Adapter
> Controller
> APC Battery BackUP
> HID-compliant mouse
> USB Root Hub
> USB Root Hub
> USB Root Hub
> USB Root Hub
> USB Root Hub
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
