Ok... I have tried this a few different ways with no luck. I have a TP Link Docsis 3.0 Cable Modem connected to a TP Link 5 Port Gb Ethernet switch connected to a TP Link Archer 2600 wifi router. Now... the wifi router has Ethernet ports, but I want to reduce the load of info going through the wifi router by having my wired devices connected separately. I'm also trying to determine why my wifi router is cutting out the 5g signal sometimes and making me restart the system, which is also why I'm trying this setup. Anyway here's what I've tried...
1. Reset everything... connected modem to switch to wifi router.
Wifi router didn't like it. Wouldn't connect. Other things connected to switch connected just fine.
2. Reset everything... connected modem straight to router and established connection, then unplugged router from modem and connected both the modem and the router to the switch and connection reestablished, but other devices connected to switch didn't like it and wouldn't connect.
3. Only thing that works for everything is to connect modem to router and use the Ethernet ports on the router itself. Although this would be ideal, I'm trying to keep my wired connections separate from my wifi router because it seems to do weird things sometimes and I always want the computer to be connected to the internet when away from home... Plex reasons. And the switch assures that.
The only thing I can figure, is that there is some kind of IP address association problem. Everything is Dynamic IP. It just doesn't make sense to me that my PC can pull an IP address from the modem through the switch, but my wifi router cannot.
Any help would be much appreciated. Thanks!
