Modular PSU replacement cables
Since you are getting a 1080ti, you should better get a new good and more importantly reliable 650W 80 Plus Gold PSU. I''ll give you 4 good options.
1)https://www.newegg.com/global/gr/Product/Product.aspx?Item=N82E16817438054 (Best price)
2)https://www.newegg.com/global/gr/Product/Product.aspx?Item=N82E16817438094 (Newer model than the above)
3)https://www.newegg.com/global/gr/Product/Product.aspx?Item=N82E16817151171
4)https://www.newegg.com/global/gr/Product/Product.aspx?Item=N82E16817139136
Each one of them is a very good PSU. Get the one that better suits your budget.
I wouldn't advice using that PSU with a 1080ti anyway. You should get a new PSU that is much better than what you currently have. Such an expensive GPU requires a good PSU. Yours is mediocre and pretty old. In order to avoid future headaches get a new and good PSU.
Any suggestions?
Thanks.
