Hi,
I recently bought a kit that can allow you to hook up a 3.5" drive to a usb on my laptop so I could work on it without it being in a computer.
Part of this kit obviously needs to supply power to the drive from the wall. The wall adapter provides a molex 4 connection, then a molex 4 to sata adapter if you have a sata drive like me.
I fried my drive with this and am very unhappy, but dont know if its what I did or if the psu is bad. I now see numbers on the molex 4 (1,2,3,4) on the different plugs, and see 1,2,3,4 on the adapter. I dont remember if they were not plugged in the right way when I did my drive, but the drive started smoking and never lived again.
Maybe I plugged them in the right way, maybe not. Would the wrong direction (4 with 1, 3 with 2, 2 with 3, and 1 with 4) kill my drive? I know the voltages on the molex 4 are different for each pin and that this could kill it.
Thoughts?? Ive looked on all of newegg's reviews for the adapter and no one seems to have made this kind of mistake. Is it just me that didnt consider this?? Or does it just not matter and the psu was just faulter and overkill.
Thanks for the help! I couldnt find anything on google that relates to direction mattering...
