Molex Power for RGB Fans and Strip
malakargaim
9
So I have this RGB Strip and 3 CoolerMaster RGB Fans being powered on this RGB Controller . When I plugged it in both the fans (which also have Molex power) and the light strip were really dim. I then found out that It was because it is a 5v Controller with a 12V strip and fans. My problem is that I don't have access to an outlet for a traditional RGB controller. I was thinking I could maybe buy this controller and this Molex power adapter to power the strip and the 3 fans. I just want to make sure this will work before I pull the trigger and buy it.
I don't understand how these things connect together.
How does the 12V power connect to the 5V controller?
I'm pretty sure these parts are not compatible.
*Do not plug those lights back into the board as you are drawing power amperage than rated through parts of the board and could DAMAGE IT.
Personally I would look at an entire kit like the "RGB Strip" that has parts that all work together.
Other:
I think maybe your confusion is that I think the "RGB Strip" page shows a WHITE power device that appears to be a 12Volt to 5V converter. So the 12V source (AC or the MOLEX adapter) plugs into that, and then you get 5V (via a USB connection) up to some maximum Amperage which I can't read.
So I think you're missing that unit which you would plug the strip into and NOT into the motherboard.
(I may have some things wrong as it's hard to see the connections in the pictures)
Also not sure how the REMOTE works but it looks like one end of the "Controller" is a receiver for the remote. So one end is power, one end is a receiver, and the other is where the strip plugs into... the receiver should just send signals to control how much power each LED strip gets.
Your kind of missing my point here. The USB controller I ordered was a controller power supply combo that was powered off of USB that used the same connector as any other RGB strip but didn't have enough voltage to properly power the lights. All I want to know is if I could use a molex to dc 12v power cable to power this RGB strip https://www.amazon.com/gp/product/B00BP4GNRY/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 and 3 RGB fans.
