Question Monitor advice for RTX 4000 Series GPUs ?
N1njaDestr0yer
237
I made this post because I'm curious as to what monitors would work with an RTX 4080 & RTX 4070 Ti, since 2560x1440p (or 2k doesn't work too well).
I was looking into 25"-27" monitors with a high refresh rate (higher than 60Hz), I wanted to get either 144Hz or higher.
Which manufacturers should I look into while avoiding others?
If I wanted to go with 2560x1440 (aka 1440p) I'd just use the RTX 3080 Ti/3090 Ti, those GPUs support that resolution.
Hey there,
Eh, what do you mean 1440p doesn't work well on those GPUs? Can you link a reference. I'm curious to know. Either way, that's not the case. All of those GPU's would be able to render fine at 1440p.
Reactions: Why_Me
That website needs to be deleted from the internet. Such useless garbage information and yet so many people buy into it like it's the gospel.
I know.... Why do such websites exist? Also do other websites that have similar "styles" of calculating bottleneck percentages? Or just the one I mentioned above?
Sorry I made a mistake, in letting a PC Bottleneck Calculator tell me that 2560x1440 will not work on the RTX 4080/4070 Ti, man I so stupid to believe that Bottleneck Calculator was "trustworthy" .... WRONG, those are so BS...
I used: https://pc-builds.com/bottleneck-calculator lol I wasn't thinking straite
Cool, I hear ya! Those bottleneck calcs are as useful as a chocolate teapot! :)
