[SOLVED] Monitor audio issues after GPU upgrade
This is a really weird issue for me and any help is greatly appreciated! It began after upgrading from a GTX 960 to a GTX 1660, around a week ago.
The audio from both of my monitors (connected to GPU via HDMI and DVI) stops working after the PC goes into sleep mode or has been on for a prolonged period of time (around an hour).
  • Restarting my PC fixes this issue temporarily.
  • The audio from my headset (USB) works perfectly all the time.
  • I've uninstalled old GPU drivers.
My Build
Mate I'm no expert here but I'm going through audio problems aswell. I would turn the sleep mode off.
Maybe have a look into your power settings and adjust to a mode that doesbt skimp on power and if that fails look into if your audio services are still running when the problem occurs. Good luck
