Monitor Buying Advice Please
bd26
67
As topic says i've decided to finally break down and buy a new flat screen monitor.
Ive had this dell one for ages but the brightness seems to be going.
With a 180-200 budget I'd be using it mainly for xbox 360/computer
This week newegg has
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001439&Tpk
for 199
and
http://www.newegg.com/Product/Product.aspx?Item=N82E16824005195&Tpk
for 189
Both seem like really good deals and i'm not sure if the 2ms would be more noticeable and the Samsung one has 2x hdmi ports which is big plus imo..... Any one have any advice or input?(esp if i can save some money somewhere)
Thanks as usual
There isn't much difference between 2ms and 5ms. Some hardcore gamers say 2ms is definitely better, but that's a matter of opinion. Other than that both monitors are more or less the same based on the specs.
$10 is not a big difference so if you really can't decide, then flip a coin. Or choose which ever "looks better" to you.
