Monitor buying help
priimalhunter
37
I know nothing about monitors and im just looking for a monitor 250 euro or cheaper if you can link me one just so it looks nice anything is helpful :) btw im from Ireland and i wont order from america or any other place dabs,newegg or pixmania would be the sites i use
Here ya go bud...you got that 970 so you should be able to push pretty good framerates in most games. This 144Hz monitor from ASUS will display those framerates for you and is pretty much a steal at €241.99..
http://www.newegg.com/global/ie/Product/Product.aspx?Item=N82E16824236313
cant get that man.. the shipping is 71 euro and that is pretty expensive then but thanks for trying to help if you see another one just link it to me :)
Would there be another local retailer that may have that same monitor model for less shipping fees and maybe even match their price? Also, I like this one too...
http://www.newegg.com/global/ie/Product/Product.aspx?Item=N82E16824236153&SortField=0&SummaryType=0&PageSize=10&SelectedRating=-1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullInfo
Looks good, almost identical specs. The one I chose has 6 video preset modes and one inch larger screen size. Yours is a great choice too, the €25.00 difference in price is up to you. If it where me, I would feel like a few extra bucks would be worth a larger screen (you plan on looking at the thing for a few years I assume.)
I cant tell if this monitor is good http://www.argos.ie/static/Product/partNumber/4179308/c_1/1%7Ccategory_root%7COffice%2C+PCs+and+phones%7C14418968/c_2/3%7C19780850%7CComputers+and+monitors%7C14419111/c_3/4%7Ccat_14419111%7CPC+monitors%7C14419112.htm
http://www.argos.ie/static/Product/partNumber/2474373/c_1/1%7Ccategory_root%7COffice%2C+PCs+and+phones%7C14418968/c_2/3%7C19780850%7CComputers+and+monitors%7C14419111/c_3/4%7Ccat_14419111%7CPC+monitors%7C14419112.htm
which one is better or are they both horrible
Choose the Samsung. The Acer is not LED backlit.
I agree with R4lNM4N, go for the Samsung
Aw shucks, thanks zallim! 😉
