This is a pretty new pc and have been successfully turned on before. I was still changing around the settings in bio,mostly ram and cpu. I didn't download anything other than gpu driver and cpu z.
So far I've tried:
1.Remove my ram and reinstall them
2.Reset CMOS by remove the battery and reinstall it after around 30 seconds
3.Remove the GPU and reinstall it.
4.Remove the DVI, power supply's cable, and monitor's cable and repulg them.
5.Tried using the HDMI cable that comes with my PS4 instead of the DVI cable that comes with my monitor.
Interestingly, this is my second time to have this problem, the first time I encounter it is when I just finished building this pc and tried to open it but I manage to solved it using the number 4 method.
But this time, nothing work, I'm a noob at building pc and pc in general so I'm pretty desperate right now.
PC spec:
CPU: AMD Ryzen 7 1700X Processor (YD170XBCAEWOF)
Motherboard:: ASUS Prime X370-Pro AMD Ryzen AM4 DDR4 DP HDMI M.2 USB 3.1 ATX X370 Motherboard with AURA Sync RGB Lighting
Ram: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz C16 Desktop Memory Kit - Black (CMK16GX4M2B3200C16)
SSD/HDD: Samsung 850 EVO 500GB 2.5-Inch SATA III Internal SSD (MZ-75E500B/AM) and WD 1 tb
GPU:EVGA GeForce GTX 1050 Ti SC GAMING, 4GB GDDR5, DX12 OSD Support (PXOC) Graphics Card 04G-P4-6253-KR
PSU:EVGA SuperNOVA 850 G2, 80+ GOLD 850W, Fully Modular
Chassis: The case already have the case fan.
OS:Microsoft Windows 10 Pro (64-bit, OEM DVD)
Case :Corsair Obsidian Series 750D Airflow Edition, Full Tower ATX Case
Sorry for my stupidity but I forgot the exact name of my monitor but it is made by ASUS.
After searching around I think it is either the ASUS VS247H-P - 23.6" LED Monitor - FullHD or the ASUS VP239H-P - 23" IPS LED Monitor - FullHD, but I'm not so sure.
So far I've tried:
PC spec:
