Question Monitor Closes Randomly when i load up games
Jul 13, 2024
4
I got a dual monitor setup G3 Odessy 1080p 144hz connected using hdmi
G5 Oddessy 27 inch 144hz connection through display port
Ryzen 3800x
Recently upgraded from rtx 2070s to rtx 4070 (Issues wasnt there before so im not sure if it is related) (I also uninstalled the old driver with DDU before isntalling the new one)
32 GB ram
The main monitor is the G5 and the game load on it and sometimes the monitor loses power and doesnt turn on through the button, i need to manually remove power/display port and put it back for the monitor to work
The issue is random
So far i tried
changing the Display port cable
Changing the port the G5 monitor connected to in the graphics card
Please include the age of the PSU apart from it's make and model. Make and model of your motherboard? BIOS version for your motherboard at this moment of time?
When using DDU, remove all GPU drivers(Intel, AMD and Nvidia) in Safe Mode then manually reinstall with the latest GPU driver sourced from Nvidia's support site for your GPU, in an elevated command, i.e, Right click installer>Run as Administrator.
PSU is about 4-5 Years old it is MPW-7001-PCABN1
Motherboard is B550 arous pro AC
Bios version F13
Bios date 01/08/21
why do i need to also remove amd for example cpu drivers if im still using the same CPU?
Latest posts
