Question Monitor compatibility ?
DavidF29
24
Is the Asus VG248GQ monitor compatible with the
Asus TUF GAMING X870-PLUS WIFI w/ DDR5-8000(OC) motherboard ?
Do I need a DisplayPort to USB 4 cable ?
What GPU do you have? You'd need a DP to DP cable, if you have an Nvidia GPU, and want to use the 165hz, and G-sync
I am purchasing the Nvidia 5070. I want to use the 165hz monitor.
